Aria with T-mobile??
Yeah I am sure you can because I know you can use the nexus one with at&t, you would need to unlock the phone though and just put in your tmobile sim.
Can I use an Aria with T-mobile?
Once you unlock your Aria, you can use it on T-Mobile for phone calls, but for data you will only get EDGE speeds; no 3G because AT&T and T-Mobile use different 3G frequencies. In the case of the Nexus One, there were 2 different models. Both would work for phone calls on either network, but there was a specific model for T-Mobile 3G support and the second one only supported AT&T 3G.
