667 Mhz overclocked(Stock clock of 551 is 600 Mhz)what it gives. what is it?![]()
how to instal step by step.or live wallpapers disappear?whether the root disappears?
Thanks for all of your effort! I'm hoping to try this out soon
Out of curiosity is it possible to view Hebrew fonts in 0.4?
Wow thanks for the super quick and detailed reply!
I actually prefer to have an English interface, I actually want to be able to view Hebrew fonts in web browsers and in apps. Is there a setting in 0.4 to fix this? Thanks again![]()
seems i cant root anymore with z4root.. phone hangs..
is there another option to root?
can't seem to find my device in socUse SOC .z4root and universalAND root dont work.
nvm .. got it solvedcan't seem to find my device in soc![]()
go to samfirmware.com and under the firmware- android -samsung 551 section .You will have a guide for flashing firmware.
root will disappear, so will all your contacts and settings .
Backup all your data.
Live wallpapers is pre-installed in the ROM.
Flash PDA using Odin .Not for amateurs though.![]()
iam an amateur, and i wish to try out this rom...any help for amateurs? any tutorial?
Thanks in advance
