Help ARM9 crash, Radio problem, keeps rebooting
kosowski
Hi there!
After coming back from a trip where I didnt used the Mobile networks at all, Im finding that every time it tries to connect to a WCDMA network it reboots, entering in a reboot loop until I disable the data connection. It only works if I set the Network mode on "GSM only" on the Mobile networks-> Network mode menu.
The error log shows at the end the following lines:
[SMD]ARM9 has CRASHED
[SMD]smem: DIAG [Radiofatal]
FATAL: rrc (rrcccm.c:04558) Failure adding acq.entry (irq:0)
Restarting Linux
I havent mess with the phone at all, no flashing, rooting or S-Off mode.
I have Android 2.3.5 with HTC Sense 3.0 and radio 20.4801.30.0822U_3822.10.08.04_M
The only thing I can think is flashing the radio, or flashing an official ROM, which for what i have understood would flash the radio too. Any advice would be highly appreciated!
Thanks in advance!
