Has anyone found a decent armband to use with their g2? Trying to find one to use while running and be able to listen to Pandora, track my route with GPS, etc. TIA![]()
If it's too big for the Arkon SM-ARMBAND, try the next size up:I ordered the Arkon armband, a really nice product but I can't recommend it to other G2 users. I had a Tmo case on my phone (the silicon grippy one) and there is no way the phone will slide into the armband with it on. If I take the case off the phone fits in the armband (barely). Once inside the case you no longer have access to the volume rockers which is a problem. I even bought a clear plastic case for the phone to see if that would solve the problem of the phone sliding into the armband but alas, no. The phone is just too big with the case on it for this armband. I am off to Best Buy to actually try out some cases and try to find a better fit.
