Armband for XE with Casemate on?
firedesire
As the heading says, has anyone used an armband for the XE that will accomodate a Sensation with a 'Casemate Barely There' cover fitted to it?
I don't like taking the Casemate off everytime I use the armband, so need one big enough to take it.
Thanks in advance...
Found one .... !
Just brougt a 'Tune Belt' from Amazon which comfortably holds the XE even with a Casemate on ... There are lots of types available both from them and other sellers but I found a model (TuneBelt AB84) which says it will suit an Sensation & 'icrap 4' with an Otterbox Defender case on, and if you've seen a Defender case before, that makes even the slimest phone look big.... A point to bear in mind though, if you have massive biceps, you will need the 'extender' strap to get a good fit. Only just got it today but first impressions are good.
