Armband suggestions
jsjames
Member
I'm looking for an armband (for working out and bike rides) that fits the charge well. Do any of you have one that you recommend?
It would be nice if it also fit the charge while it's in the Verizon kickstand case.
Err..........
I got one from Walmart a while back that is like a 1/4 sleeve with a pocket in it that works awesome. They come in different sizes and it is made by Philips. It's a black sleeve (only way to describe it) that just slides up on your bicep that has a pocket that the phone slides into. It is stretchy so the case shouldn't be a problem. I use mine for running all the time and it works great.
I can't beleive that these are this hard to find. I've looked at Target, WalMart and Best Buy without any luck. Amazon has a few that they say fits the charge but the headphone hole does not line up.
Maybe someone else here has bought one since my first post.
The PDO Sporteer is really good. The front has a clear, touch-sensitive screen and works great. The top is open and on the bottom, there is anopening for various earphone jack positions. I'm not sure abpout the chargers for all models, though.
