Lol do you guys just call 911 for any random junk?
I've never dialed 911 in my life...
When you dial 911 does it use the GPS? I have had my phone reset several times when I have made a phone call when I was using navigation.
Smart Phone Fails Some Customers In Emergencies | KSTP TV - Minneapolis and St. Paul
i hope th OP didnt get banned resulting from this post...he had something going too
I'm from Minneapolis where this video is from and that channel, rather all of them in the metro area, are big iPhone fans. I saw many many iPhone stories, and never one for the Evo until now that there is a "problem". I know it is a side issue, but I think it is a factor (Or maybe I am just biased since I have an Evo?)
Just tested in Alaska and it works just fine... I feel safer now
I was in a car accident (everyone is fine) about three weeks ago. Had to dial 911. I connected just fine. Phone does go into some sort of emergency mode for about five minutes like previously posted. I thought I might look it up but forgot all about it.
virtually all handsets have to be able to make 911 calls.
handsets go into a emergency mode sending GPS location to the PSAP's who field calls in that area. some handsets must be soft reset to get out of this emergency mode so what you saw was completely normal.
I think anyone who uses a smartphone that allows software to be added has had their phone reboot unexpectedly.
But if you've had two phones in a row reboot this way, I think you should look at what software you have running on it. Spontaneous reboots are usually caused by some kind of software conflict.
Even if your call gets cut off, they will dispatch the authorities to the area.
Even though its a inconvenience for a phone to cut out during a call ... you can plan on them responding no matter what.
