Help ascend hangs on "ANDROID"
Nope, its an ascend. :D
Follow the guide in my signature to flash one of four options stock, icarus1.1, Cm6 or cm7.
If it happened after trying a flash then redownload (on PC) and try again
I usually flash stock (broke my SD reader) to unbrick first, then flash a rom.
how can i flash it? he has a stock recovery (this sint my ascend im fixing it for a friend)
i cant get into debugging to install CWM to flash cm7 (i was gonna do that n the first place)
Flash to stock (according to carrier, look in the first post on my guide for a link to stock guide)
Then flash cwm via fastboot (or root and use RomManager)
Flash cm7 once you get cwm on.
