Ascending ring
skrapmetal
My ringtone ring starts out lower and raises, but I haven't found a setting to change it. Its really annoying if I'm at work due to the noise so I usually miss calls just by a split second. Any way to correct this?
I believe that works as designed, thus the word "ascending"
You can make a custom ringtone from an .MP3 or simply pick a different ringtone.
