Help Assigning ringtones?
Open up the contact for edit. Scroll all the way down to the bottom and select Additional Info. Scroll down to Call Handling and select the ringtone you want to use. You'll need to do this for each individual contact, otherwise it will use the default ringtone.
Good luck.
