Root assistance with cm7 settings please
demalii
If anyone can help... I'm trying to make launcher pro as my default home... but when I reboot my settings to make launcher pro the default home is no longer. I have to select launcher pro as the default again making the Widgets not load.. is there some settings I'm missing?
I also set advanced task killer to load on startup but even that doesnt work.. assistance needed. Thanks.
Hey demalii,
After installing LP you could try uninstalling ADW to make LP your only home app but that may not be the best solution. I am not sure why you are having these problems it may be specific for your device as I have ran CM on several phone and not had the issue. What phone do you have so we can try to get you some better answers?
Moved thread to the Huawei Ascend All things Root forum. There should be users here more familiar with your phone and the roms specific to it.
ADW is the stock launcher app on CM7 at least for what I have seen it on.
Move launcher pro to the system>app folder. If your sd card is partitioned it will be in the ext>apps folder. If not it will be in the data>apps folder. Just move it to the system app folder and delete adw. Just make sure you installed and set LP as the default first.
Their not on the sd card. Download root explorer or I think you can do it with ES File explorer too, I use root explorer and then look for the files.
Ohh, jeeze... So I had a weird thought because I'm the only one with this issue. launcher pro and advanced task killer were both saved to the sD card, so those progrms weren't actually able to start up. Thx for everything!
