Root [AT&T] Convince me please..
Androidkucool
I've rooted on my previous phone (lg esteem metropcs) because the metro adv were very very annoyed me (they were at least twice a day on that time). I don't see an att adv at all and everything are very fast compare with my previous one (one core vs quad cores duh...). Also, I've seen that rooted note 2 will be "erased" some note 2 features, is that true? Anyway, pls convince me why i should root this note 2. Thx...:D
Cpu controle for battery life
Greenify for battery life
Titanium backup
Flashing roms
Boot animations
Ui sounds
Root access to manually install apps if android os gives you hassle
Custum roms
Bloat removal
Apn backup and restore usage
Tweaks
Xprivacy.apk, to controle permissions on an app by app basis
And the list continues...
Your choice.
Stick with tw based roms
Jedix or jedi master on xda are great choices.
Aosp aokp or cm you will loose some fuctionality due to no touch wiz
Great list! If that does not sway someone. I don't know what would. But, for me the greatest advantage was the removal of all that crap bloatware.
Its simple. This is my phone. I bought and paid for it. I should not be dictated to or lose control over what apps are on it. Remove bloatware = faster phone, More space for apps you actually use, and last but not least. Better battery life.
