sparker781
Member
Yeah guess so. Since there is no real clear cut way to root and flash a rom on this.....
Thanks
Thanks
That could be a handy back-to-stock if you can get it. Where would you get it from?since i can't seem to find one available , im gonna upload an odin flashable mk2 so you can return to stock (i think thats what you were wanting to do yes?)
Root shouldn’t be a problem. I think what throws a lot of people off is the fact that there are so many old rooting and flashing instructions (for previous S4 firmware versions) floating around. Things have changed so much that those simply won't work anymore. You've just got to find instructions that are applicable to your particular version of the firmware. Take a look at the 2nd post in the thread linked below (the post that starts “If you are currently running the MF3 or MK2 build, this portion of the guide is for you.” ). It gives a good overview of the state of affairs for MK2 and what you need to do to root (“step 2”since there is no real clear cut way to root and flash a rom on this.....
and what are your options with Safestrap.So can I get an answer to how I fix the lock iocon from showing unlocked when I boot my phone?
