Root [AT&T] HELP Unrooting Note 2 for atnt
ni3kel9
I installed paranoid andriod 3.99 which upgraded my phone to a 4.3 and I wanted to unroot my phone but it somehow got bricked. It turns on but on keeps repeating on my samsung and atnt logos.
WHat should i try.
WHat should i try.
If you knew how to install a rom. You should know the first thing to try would be to boot to recovery and do a factory reset(clear data, cache, etc.etc.) How you would depends on what recovery you have? Stock or custom? There are directions for both everywhere. Btw, if you do have a custom recovery. You could try just wiping cache first before a data reset. If this does not work...Then its on to Odin...Again, since you flashed a rom. I assume you know what I mean.
