I have no way to access wifi right now.I tried but says no update.Prob won't let me where i done the RUU update.I would love to update to the newest version but how?Hopefully someone will cook up another RUU to do this.The link glitch is really annoying!Dude....did you try flashing it???
I don't think its the sameyou're probably right...i'm just curious to see if there was any difference at all(i don't think there will be)
If anyone does use the OTA update, i'd be interesting in seeing what version of software comes up in your phone afterwards. Ours is 4.0.3RD or something like that...i'm curious if its the same...
Only way i have found it is to remove your clock or weather widget from your home screen.Add it back and when you do it will give you the option to disable full screen animations.You can open weather widget settings and also turn off weather sounds.I was able to get the update over wifi at about 7:15 pm west coast time. I my one question is how do you turn off the animations? I can't find it in the settings menu.
So this is weird. I went to Settings and clicked on Check for Update, and it said my phone was already up to date. So I figured maybe it's not available in my area yet. I went to the AT&T website that was posted to get info, then tried again. Now I get a message that the install was interrupted and I have to wait 23 hrs and 18 min to try again. Huh?
A new RUU 3.26.502.56 was released last night by PG.Now im just trying to figure out how to run this after i ran the 3.26.502.52 RUU.
run the RUU if you don't wanna wait...its the same thing. RUU=Rom Update Utility. THat means that its signed by HTC...an official update...it will wipe the phone though...
Im pretty sure it does.Ugh. I'd love to avoid that, if possible. Does updating via the phone wipe it as well?
I finally got it to download from WildChilds sitesame here. I tried downloading the RUU on from the link he posted on his website but it kept timing me out and downloading real slow. I tried all night. I need to find another site that has it so that I can do it manually as well. Do you know of any other place that has .56 posted?
Thanks alot for the help and for uploading the RUU for usCustom and ruu are on my site now....
