Root [AT&T] JediX Upgrade....help please.
What's up all? Just wanted to ask about upgrading JediX on my Note 2. I am running Jedix 16. I want to know if I can go to Jedix 19 or 20, without wiping my entire phone again? Can I simply just upgrade and keep all my info in tact? Or do you have to do a clean wipe every time you install a new rom? I backed up my phone to my sd card, so lets just say that I have to do a clean wipe. If i install a new jedix, can i just put my backup on the new version? even though i backed up on an old version? Help please.
Ok.
You can not wipe. But I would never do this again after doing it once. It'll be a little buggy.
Try titanium backup
I wip, flash rom, Install titanium backup and then batch restore all user apps with data.
Then the only thing I haft to set is my walpaper and widgets and lock screen shortcuts.
Also bluetooth and wifi.
You can back those up to I just usualy set titanium to auto backup user apps plus data 2 times a week.
Dont backup system apps.
Should fix your issue with long system rebuild times after flash with no bugs from a "dirty flash"
I run jedix on tmobile version by the way.
Ive dirty flashed once.
Try it, bet you wont like it ;)
It wont break anything, itll just be anyoing, like longer boot times and sometimes app foce closes.
