Talking about GPS issues!!!!!! I live in Miami and last weekend Myself and the little man took a trip to Daytone for the Supercross Event and GPS literally every 5mins went out. I must restarted the phone 12 times thinking that would fix the issue and to no avail. Is this software or handset related? At&t has sure been slacking!!
The easiest way to really show impact is:
I found the last one is the biggest PIA as I travel to new cities often and have no idea when I change towers/coverage areas and in the midst of navigating it will drop on me. I most recently was in Hawaii on the island of Kauai and it dropped nearly every 2 minutes, I'd restart the GPS, bam it would drop again. There it wasn't even changing back and forth as I didn't have much if any LTE coverage it was all 4G. I can only assume it was due to the mountains and elevation changes I was seeing that caused towers to jump and the GPS to drop.
- Navigate via google and then make/take a phone call. The GPS will drop within seconds.
- Have someone send you 1-2 text messages while you're navigating, it will drop you.
- Some will say simply plug your phone in to charge while navigating. I suppose that works, but I always plug mine in to charge when in the car and I tend to do so before I roll out.
- Lastly, use navigation while crossing to/from and area of LTE/4G coverage. For me typically as I roll east or west out of my city I will lose LTE coverage. Bam! GPS will drop.
