Root [AT&T] MMS Not Working?
Dottio123
Flashed Android Revolution 40.3 and I noticed that my MMS isn't working. I'm unable to send or recieve. I've gad the ROM for awhile and I thought it was working before, but it certainly isn't now. I checked my APN a dozen times and it matches AT&T's settings or whatever I could find on the internet, but nothing seems to work.
SMS and Data work just fine, so I don't know where the problem lies.
I'd post on the XDA Forums, but new members aren't allowed in that section. I also searched it and found one or two posts with my problem, but no mention of a fix.
Any help would be a appreciated.
I really have no idea
flash another rom and see if it works
do you have an at&t device?
you can try using gm sms to send mms. if needed,go has an advnaced setting that you can input APNs directly into the app. it worked to be able to send mms on my vzw dna on straight talk :eek:
sometimes,all you need to do is install go sms,and then send a few pics with it,then the stock app will work.
aside from that,i dont really have any ideas either. usually mms are only an issue on cdma "world phones" that are being used on a us gsm carrier.
Hey, all. Thanks for the suggestions, but I just flashed the GPE RUU and everything is working fine.
I didn't use the Sense features that much, so it's not that bad. I kind of like it more actually.
