AT&T Note 2 Questions regarding the Lock Screen
DMS1
I have had my AT&T branded Note 2 for about a week now and was wondering how to use the 4 icons on the bottom of the home\main screen (the screen you swipe before the security screen). It seems once I added security those icons dont work anymore unless I do the swipe.
Is there a way to setup those icons to work even if the device is locked? I would like to be able to use the phone and camera even if the device is locked. Is this possible? Can those icons be changed?
Thanks in advance
Dave S
Go to settings then lock screen and all the options to enable the icons to be used or changed or to add tickers and enable camera shortcut are there.
