Hello all,
My S3 currently has TWRP 2.7.0.1 recovery and CM11 installed. It was also previously encrypted.
Recently the gapps on my S3 have completely stopped working. New accounts cannot be added and the programs immediately crash upon starting. Deleting the app-data for these has had no effect.
While I can decrypt the phone for regular use, I cannot do the same in recovery to reinstall gapps. Consequentially, it appears that the best option would be to wipe out everything to get rid of the encryption. Unfortunately, it seems that you cannot flash a new ROM over an encrypted partition via recovery. I have reached the conclusion that Odin should be used to reformat everything.
Is this a correct understanding? And how would I go about doing this safely?
Thanks,
quib
Thanks,
quib
