flash a factory at&t rom and that will return it to factory state. But, if when u boot into download mode, it shows that the device has been modified (the flash counter), use the Triangle Away app to reset the counter and then unroot :thumbup:
If you can find a zip of the firmware then use CWM but if you have a pc, use Odin and get the firmware from sammobile.com
remember though, Triangle Away will only work while youre rooted so do that 1st :thumbup:
If anybody knows of a link for the file, let me know.Ok that worked awesome! Returned phone to stock ROM, Reset Custom Counter, and Unrooted my phone! You are the best!
I am facing the same problem. but phone is not from any of the mentioned phone companies. so i need a basic rom with unroot and get rid of cwm recovery system.
It would be a great help if any of you can help. also please tell me the process to do this thing.
Thanks
