Root [AT&T] Unlocked the Bootloader...how best to proceed?
RicKaysen
Member
I'm a little squeamish about rooting my M7/AT&T One. I've managed to get the bootloader unlocked, but as I attempt to follow the step by step instructions, my eyes start to glaze over. I've searched for an easier, one click style root method, but the feedback is so minimal on the sites I've seen, I don't trust that they're safe. I want to root it to gain only one function: tethering with PDANet/FoxFi. I don't care about custom ROMs and such. Can anyone recommend a tried and trusted one click method? TIA
i believe that tool is trying to use a temp root method to inject the su app and binary. even if the app manages to do so,an s on phone has write protections that will prevent those from remaining after a reboot,even with an unlocked bootloader.
from the description its not not doing anything to install a recovery,just attempting to add root access.
IMO,youre still better off manually adding a recovery and flashing the superuser files via the recovery. fact is phones are becoming too complex for universal one click methods to be of much use,and you may need the knowledge you get from the inital rooting process in order to fix minor issues that can arise from it.
again,just my 2 cents :)
