I got it to root. I didnt do anything different, It just takes multiple times before it catches. Im talking 10 - 15 times before it caught. So i am thinking it is a software issue and phone issue. Not compatible?
Now i saved all my progress. I have Titanium Pro installed.
Here is another place where things get messed up. I flash the rom and the kernels and start the phone. Everything works, But the texting incoming and outgoing will not work. So i am leaving the phone where it is for now. I dont know what i should do from here. I need to have texting abilities.
firmware
2.1 update1
base band
S:i500.04VDIo1
Kernel
2.6.29
build
SCG-I500.DH12
I used the
i500-VZW kernel
I used everything VZW to get it to stock so why is it saying DI01 in baseband? Is that right?
Does something change when i use that update.zip file?
reset and restarted. Getting force closes. first on TW screen then on process android media has stopped.
cant do nothing on phone. Popping up all over the place
Shouldn't the build number match the baseband?(both be di01 in this case)
It worked and i can text. i used adryns all in one di01 so the build matches the baseband. So from here i save it and back up. Now i can play with other roms and kernels?
