Help Atrix doing strange things
imjason
2
0
I've had my atrix for almost two months and recently my phone started acting strange. For one thing sometimes my phone doesn't give me a notification if i get a text, the LED doesn't even blink. Another thing is that the keyboard forcloses on me normally while texting, and sometimes my texts dont' go through to the other person. At first i thought it was "GO SMS PRO" but i uninstalled and still having the same problems using the stock texting app. Other then that my phone seems to be fine. I don't know what i should do since im over my 30 day warranty from AT&T. Any help would be appreciated. Thank you.
1. go to your 'settings' then 'display' then notification led, make sure that is checked.
2. do u reboot or turn off your phone every once in a while? while i think motorola suggests turning it on and off everyday is a bit excessive, every once in a while you should turn it off at night or something and turn it back on in the morning
Upvote 0
i did turn on the notification light, it was always on. And i turn the phone on and off every 100 hours of use or so. The notification icon seems to go away when i press the lock/unlock screen sometimes as well.
then i can only say it must be one of your applications messing with it. i forgot what app it was i previously had it installed and i too had the same problem as you. so i uninstalled it.
maybe check to see what app has an notification led option and that might be the culprit..
Upvote 0
BEST TECH IN 2023
Smartphones
