Atrix is too slow (redux)
Czarcat
I see many negative threads related to the Atrix and some aspect that is considered to be slow and therefore the Atrix must not be a capable device declaration.
I think much of this has been pointed out previously but I don't think it's been grouped into a single post. Forgive me if I'm being redundant.
Browser pinch to zoom
The stock browser is choppy on the pinch to zoom and scrolling.
This is a stock browser issue and to me is resolved by using an alternative browser such as Dolphin HD or Miren. Try them both and see if you like one of them.
Gallery pinch to zoom
The stock gallery app does not pinch to zoom smoothly.
This, to me, is the most egregious of failures. Since this is a Motorola modified gallery app and is not the stock Android 2.2 app, this must be a Motorola introduced issue. In fact, Motorola should be embarrassed at how poorly this app zooms in and out.
This can be completely resolved by using an alternative gallery app such as QuickPic. This provides a vastly superior way to view pics on the Atrix. The ability to zoom in and out is extremely smooth.
Motoblur UI
The stock UI is Motoblur aka Molasses Blur.
You can't remove Motoblur from the Atrix. However, you can banish it to the kiddie table in the next room by replacing the default launcher.
I prefer LauncherPro but ADW or others will work just as well. This provides many new features not the least of which is super smooth home screen navigation.
Summary
My personal opinion is that the complaints are all very valid. However, the beauty of Android is that you can generally change what you don't like for something you do like.
The fact that these replacement apps can provide the experience that the stock Motorola provided apps didn't proves that the Atrix is more than capable. The issue is that Motorola provided a sub-par out of the box experience.
...The issue is that Motorola provided a sub-par out of the box experience.
I agree 100%.
They could have included various app's that would have wowed us after promoting it as its new flagship smartphone. Instead we get a bada$$ phone with poor apps etc. Good thing is that it is very capable:).
Yea it works for the most part, but hey Czar I have a app called SDX stock removal and if I remove Blur services you think the phone will crash?
not sure what you guys do to your phones but I have never had an ounce of lag nor have I had trouble with pinch to zoom. Maybe I'm lucky...who knows
It's not an issue of things not working. The stock apps work. If you just use the Atrix and nothing else, you'd likely be quite pleased.
By comparison, though, certain things are not as smooth as they are on other devices. For example, pinch to zoom in the gallery is horrible when compared to the HTC Inspire or iPhone. It works but it isn't smooth like it should be or clearly can be.
Download the free Quickpic app and check it out. The difference is startling and proves the issue is not hardware.
Motoblur UI
Summary
agree %100..i couldnt stand the the lag, switched to the inspire and im happy. hopefully motorola will come out with a better phone and ill be back
It's all about the user. The phone is ready to be customized to whatever needs you have, but if you do not know what you realy need and do not know or do not care to customize it - plus you have no idea about maintenance - the phone will crap out on you the same way a computer, car, bike or any other piece of equipment would.
My point was that it isn't an issue with the phone at all. It's just some poor software by Motorola which is easily fixed by the alternative apps I listed.
The Inspire is a great phone and I love mine. The Sense software is highly optimized and it shows. It just demonstrates my point about good software.
I Agree, had my phone since day one.. running stock, no tweaks, no hacks, a few basic apps from the Market and Exchange and my phone hasnt lagged yet. i carry my iP4 and Atrix daily, and its browser is just as good as my iP4.
Hmmm, after viewing your video, there is cleary some lag with the stock app when compared to the 3rd party apps. hopefully motorola updates these apps in the future.
