Root atrix lost root with 2.3.6 upgrade
racypdx
just got the phone. love it. rooted it with a one-click program. perfect. started loading programs. then decided to check for system upgrades, not knowing what it really did.
not root. apps broken or not showing up.
- How can i root this new 2.3.6 ?
- or how can i revert to 2.3.4, which worked perfectly and came with t he phone?
I only had it rooted for a couple days, so i hadn't backed up anything yet - which means i didn't know how yet.
is there anything i can do?
thank you, all.
try running the same one click app again.
i also have the 2.3.4 and dont want to update until i know exactly how to root, and when i am sure my webtop hack will still work
trust me, i tried Pete's one-click root as soon as i realized what happened. no go. Fails. they must have fixed the exploit. sofar, there's about zilch on the net regarding this problem.
Guide can be found @ androidadvices dot com/root-motorola-atrix-4g-45141-gingerbread-236-firmware/2/
Had to use the alt method but it worked great, hope it helps!
It doesn't work for me, I can't get past this bit:
"After this, your phone will be rebooted. Wait for the phone to get rebooted and then you need to type in the command as
