ATT MMS settings?
So for the longest time I've been unable to recieve MMS messages
and now it's finally frustated me.
So does anybody know settings that will work?? Much appreciated.
Do you have data on? Have you checked the APN settings? Are you using something to modify your APN? Have you checked the settings under messages?
You have to give a little more than "someone make it work".
Yes I have data on.
I've been looking around, trying to figure out why but nothing has seemed to work.
Yes that's why I'm asking for the APN settings, or is it just MediaNet?
AT&T
APN: wap.cingular
Username: WAP@CINGULARGPRS.COM
Password: CINGULAR1 (must be in CAPS)
Expanded Version:
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Username:WAP@CINGULARGPRS.COM
Password:CINGULAR1 (yes this is in CAPS)
Server: leave blank
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS Port: 80
MCC:310
MNC:410 (note: this could also be 310, 41 or 15)
APN Type: leave blank
Good Luck!!
