Attention Shapewriter users...help needed
I am planning on doing a hard reset on my phone, but don't see a way to back up my Shapewriter keyboard using Astro (it says that it is "private").
Is there a way to either:
1. Backup Shapewriter so that I can install it from my SD card after the reset?
2. Download the Shapewriter keyboard after I perform the reset?
For what it is worth, I have version 3.0.9, so I would want either this or anything more recent, if possible.
To those that are planning on recommending Swype or SlideIt, thank you for your input, but I find both of those far inferior to Shapewriter.
I guess I should learn that there is a plethora of apps out there that don't show up in the market. I will try that. I just assume I have to rebuild my library of learned words. Oh well.
