Help Audio Book Playback
hi,
When I play back an audio book through bluetooth in my car, the track resets to 0.00 mins once I turn the engine off - is there any way that the phone can remember and start from where it was stopped
First off welcome to the forums :)
You might have to try and different application to be honest. Otherwise it will probably just reset every time. Try seeing if their is an update to the software of your BT device.
hi,
Don't know what app you are using but I use Smart AudioBook Player and never had a problem.
This is not a free app but a donationware, will cost you $1 minimum. IMO, way more worth than a $.
