Help Audio enhancer crashes.
Yes, it says resetting in 3,2, 1 and it sits there at 1 forever. As I said , this worked before, now it doesn't.
apologies for jumping in, but are you scared to do a factory reset?
tried letting the battery deplete all the way?
are you rooted by chance?
(didnt read all the back and forth here, just doing a random drive by) :D
No, I'm not really scared doing a factory reset, but I have a lot installed on the phone and that seems like a lot of work for something that is just an annoyance. I don't think I have ever let a battery run down lower the 40% on any phone , ever. I charge my phone every night. The phone is not rooted, nor probably ever will be as I am just not that ambitious and already does more then I could ask for or need from a phone. I listen to lots of music, text, call and surf. Its already light years ahead of my previous 5 Blackberrys. Just having no battery to pull or replace is just stupid to me. With this annoyance it will now be a requirement on my next phone, whatever brand that will be. Probably an SD card too, as I have less than 5 gigs left.Thanks for the response.
Ditto here,holding power button down does nothing but bring up the menu & the countdown,but,does not re-boot w/this method.
Have you tried booting into recovery & wiping the cache partition?
I think this is an equivalent (or close to it) of a battery pull.
I respectfully disagree.
not to get this thread too off topic, pressing and holding the power button will cause the phone to countdown 3.2.1... screen goes black.
CONTINUE to HOLD DOWN the power button and it will reboot.
do I need to post a video to prove this? Plus its all over the internet.
I /we are not saying your device doesn't do it, but, ours doesn't.
What's so hard to believe about that?
It's a fairly straightforward procedure, & it just doesn't work the same for everyone.
Exactly. I get what you all are saying, but THIS DOES NOT WORK ANYMORE ON MY phone. While help is appreciated, to keep suggesting I am doing something wrong because other phones worked this way isn't helpful. It worked before , now it doesn't. Lets just move on I guess. Sorry to take this thread in a different direction. All help was appreciated.
That seems to have been the issue. I have a bunch of "unknown artists" and "unknown songs" in my playlist, it was probably trying to update those in the background. I didn't even think of that. Thanks for the suggestion, hopefully this fixes the issue for good.
Hi Ironman, I also have the identical issue with my M8. Only just started but reading this I think the other chap was right in that it maybe the updates in the background as the only change I can recall was copying a bunch of music across to my SD card.
To confirm did you just disable the 'updates' in the apps settings area and that resolved the fault?
Strange issue as it doesn't seem to actually crash the app just chucks out a nasty warning...
Appreciate your feedback.
