So.. Im Running Dirty Unicorns V 4.2.2 And My Alarm In The Morning Nor Is My Music Any wear As Loud As It Is On some Roms. no play store equalizers work and dsp manager wil not install. any advice?
Do you really have to be on a Non-Sense ROM to use Acid tho?
You need to find the 3.7.0 universal Anthrax kernel. That will make your phone sing like the fat lady.![]()
Brian706: Thought I'd start with the Acid audio mod, what's the install process.
Running: AlienDroid 1.0
4ext recovery
I downloaded the zip file for acid mod 10.0, steps to install. Do I need to follow steps like clearing cache, like did with the jellybean mods?? etc.
Originally Posted by ilya404
1.Take nandroid backup
2. Wipe Cache and Dalvik Cache
3.Flash the downloaded file in CWM (First 2802 then 2805 then Clear Audio)
4.Wipe dalvik cache + Cache
5.fix permission in recovery
6.reboot your phone
7. Check buildprop and use terminal emulator to fix it (su[enter] mount -o rw,remount /system[enter] aengine[enter])
8. Reboot
Where did you get version 10? On their page they are on version 7. And the instructions they list are:
You can view their page here: http://forum.xda-developers.com/showthread.php?t=1923630
Brian706: my bad, remember new at this. The link posted above by negamann303, goes to xda. acid audio port 10.0. I need to read better. I will follow your steps. Thanks for the help.
The AC!D audio mod in the Evo 3D themes and apps forum on XDA is out of date now and I'd recommend using the version on the developers page at this point. The reason the one in the Evo 3D forums was created is because the older versions of AC!D didn't work on the Evo 3D/V without being modified but the current one does. There are also conflicts in that version between other enhancements like the walkman player and noozxoide equalizer that have been resolved on the developers version.Well the instructions might be different for their port. Mobz said just wiping cache and dalvik should be fine for that version
So are you flashing Version 7 or the 10.1 port? 4ext recovery is fine and will work.
No, just the opposite.So if understand ramjet73, I should use the 10.1 port. I was going to flash the version 7. Being new to the site. I don't understand #7 on Brian706 posting.
So I should be fine clearing the cache and flashing the acid zip file??
So will be flashing v7. On step 7 above. Can you walk me thru that step. Once my phone reboots. What am I doing to complete this step. Lost me there.
Method 2(Thanks to Deliquified for the tip)
Type
Code:
su mount -o rw,remount /system aaengine
Other[Apps tweeks etc]
Click here to download audiofx widget
4ext is based off of Clockwork Mod and CWM is not recommended for this device. Stick with 4ext. Yes you will have the option of which one to flash. Put them all on your sd card, and when you choose to install from sd card, select the 2802 first. When it's finished, choose install again, and then pick 2805. Then clear audio.brian706: I want to thank you for your help, since found this site. On another site, (won't mention) when asked a question. I was told if your to stupid to understand what that stands for, you won't be able to root your android.
It's no problemI never understood why people are rude like that. Isn't a forum for asking questions? If you don't want to answer questions, why are you even there??
i'm sure you experts would like us new folk to learn the basics and lingo. So on step# 3, it refers to the cwm or clock work mod. I'm flashing file from 4ext this v7 file. Do I need this clock work mod?? Using 4ext will I be given the option to flash First 2802 then 2805. How to clear the audio. Thanks again.
