Audio getting out of sync when fast forwarding video
fizgig
Anyone else see this? If I start the video from scratch and let it play all the way through, audio is synced just fine.
When I drag the slider to another point in the movie, it's now off by a second.
If you aren't seeing this behavior on yours, would you mind telling me the compression method you did?
I've played with multiple compression settings and had the same problem every time.
Just tried the handbrake method found here: http://androidforums.com/how-tips/14610-put-videos-droid.html and it worked great. Fast forwarding didn't have any affect. The only deviation I did (and it might or might not be advisable was that I changed the video quality from "Constant Quality" to "Avg Bitrate" of 1000.
I forget what program I had compressed the other video with (did it for my iphone a long time ago).
Will use handbrake from now on.
