Help Audio Issues
Ok, so i have sound on my device for notifications and such, but not for audio when decoded by HW. When i use MX Video Player it will play audio with SW decoding but HW is way smoother but i get no audio. Movies/Video app wont play sound at all. Media volume is all the way up.
Anyone have any ideas as to the issue or what i could have screwed up. I am running CM A3 and the SOD fix from dalingrin. Thanks
"CM A3 and the SOD fix"?
The sod fix is just for A2.1. :D
Try reflashing A3 and see if that fixes the issue. A3 includes the SOD fix, but flashing the fix after might be causing the problem.
I tried just reloading the CM7a3 and it didn't change the no audio.
Thanks though. I have like sound effects and such but no audio when using hardware encoding.
I saw a couple of issues that might affect your problem (but didn't read them). I'm guessing that after Alpha 4 we might be into ICS code, which supports more h/w accel.
If your issue isn't described there, you should add it.
