Help audio jack
i noticed yesturday that my audio jack is not working on the t-bolt. anybody else have this problem. was in my buddy's focus with sync did a line in and mine didn't work he has the t-bolt also and his worked. came home plugged some headphones in and same thing the audio jack is not registering the headphones. looks like i'm taking it back for a new one.
I just checked my TB and my headphones work just fine and I also use it in my car with the Aux cable to listen to DC 101 on I heart radio. Take it back.
Make sure your headphones have 3 stripes instead of 2. See link:
http://androidforums.com/htc-thunderbolt/300972-headphones-listen-music-answer-call.html#post2523415
Headphone jack has been working perfectly for me, but now all of the sudden as of yesterday it has stopped working at all...tried 3 different headphones...no sound at all...:(...software problem or definite hardware problem? This will be the 2nd time I will have to replace it if it is a hardware problem with the phone...
Hmmm...just for the heck of it, I decided to do a battery pull and then reboot, and guess what...my audio jack has started working again! Does that mean this is a software bug that HTC needs to be made aware of and fix?
