I use my phone as my primary audio source on my motorcycle through the 3.5 jack into my bikes stereo. With the Note 2, each time I plug the phone in the volume drops to 50%. I always ride with it at 100% and control the volume through my stereo. The holster that holds the phone on the handlebars covers the volume rocker switches making it hard to raise the volume. Is there a setting that would leave the volume at 100% all the time?
My EVO didn't have this problem and I've looked for a solution but haven't found it yet.
Thanks for any help
Not sure you're aware, so I apologize if you had already checked it, but the general volume rocker when turning the volume down or up does not affect the other sounds, unless you go all the way silent or put the phone on vibrate mode. So, even if you may be using the volume rocker to turn the volume up and down, that doesn't necessarily mean that your notifications/media/system volume are going to turn up/down also.
On the original EVO 4G, there was a toggle for the volume rocker to control all of the sound settings when turning the volume up and down.
Easy way to find out is, press the volume rocker up or down and then click on the settings cog when the pop-up comes up. On the Sprint version, after pressing that cog, you should see:
Phone
Media
Notifications
System
Each one having a separate level bar to control the volume. Make sure that your Media volume is turned all the way up and you really shouldn't have any problem.
Now...if you were already aware of this, my follow-up questions would be,
- what music player do you use?
- Do you use stereo headphones?
- Did you check the accessibility settings to see if the "Mono" is toggled off, for when you're connected with a headset.
