welcome to http://androidforums.com try this out and if it still doesnt work,i would recommend creating a free account with us and look up your phone forum and see if theres any posts,or someone in the forum there would be able to serve you more,but i believe this should do it-----Set Static IP in SGS3
- enable phone wifi then connected to wifi
-Setting >wi-fi >long press the Wi-Fi network that you connected >Modify network config.>enable Show advanced options that you will find the way to set static ip
- Reload WiFi Driver
- Use Different Options to Reload WiFi Driver
- Modify Network Configurations
- Clean Device Cache
- Try Wi-Fi Fixer App to Resolve the Problem
