I just finally got around to noticing that when using the automatic setting my droid does not dim all the way in the dark, and does not brighten all the way in the sun. manually dimming and brightening gives much better results.
So my question is, has anyone found a way to change the droids auto brightness behavior? for example some way to adjust the range of brightness the automatic setting can use
I know you can manually do it with widgets etc... But there really doesn't seem to be anything wrong with the automatic setting besides how much it will let the phone dim or brighten up.
