hdsixhundred
Member
I have noticed that when you open up a web page or email the screen dims a little bit. Its minor and would probably be unnoticeable but as soon as you bring up the keyboard the screen lights up and gets to the DEFAULT brightness. I have auto brightness off and I have used power widget to set it to brightest, mid and lowest and it does it on all. I even went as far as removing power widget then using brighness under settings but it STILL dimms when pages are loaded/email and a few other apps. Incredibly annoying anyone else notice this and possible have a fix? Thanks!
