Root auto installer for cwm and stock recovery
Frank The Tank
can someone point me to a link for the autoinstaller for cwm and stock recovery. I need it to get back stock recovery.
I had to wipe my computer
much thanks:p
Ok man it worked. I used the terminal emulator. Man but the autoinstaller is so much easier. if anyone has that, please post a link for me. I like to have it handy
the auto installer for pc is simple, all i did was take the commands you would normally use and put them in a .bat file for a windows pc
adb reboot bootloader
fastboot flash recovery recovery.img
and have the thing you wanna flash named recovery.img, as well as the fastboot and adb programs in the same folder as the .bat you made. done and done. and if you want to make it fancy
fastboot flash recovery %1
that will make it drag and drop capable, meaning if you drag any image from anywhere no matter what its called itll install it for you. just gotta still have it and both the fastboot and adb programs in the same directory as your batch file
this can even be done with the dd/adb method
adb push %1 /cache/recovery.img
adb shell "su -c 'dd if=/cache/recovery.img of=/dev/block/mmcblk0p13; rm /cache/recovery.img'
i might come out with an updated installer, but i make no promises, and whatever you do dont drag and drop the wrong files onto those lol you wont like what you get
Wow. Im going to look up on how to make a .bat file. Im learning alot in these forums. Thanks
Off subject here but, windows 8 is not a good thing. I was using a vpn server and was still able to find my location on the maps app. There is no real privacy online.
or course windows 8 is a bad thing, look at it... lol. but i dunno what youre talking about bk, if you are saying making a batch file didnt work then thats an issue with not being able to rename shit right because you have hide known extensions turned on under folder options, if youre saying that the bat files that i made didnt work that is either a problem with the fastboot methods compatability with your computer or something else got screwed up, because if the root method worked then these scripts should work
I still got the auto installer. If someone wants to put a link up for it that's cool, just pm me an email so I can send it to whoever. Just trying to help.
It may be easier but u dont have to worry about drivers nd shit like dat cuz alot of ppl have trouble even getting there phn to work on pc
right, but you cant root without a pc, and you cant install cwm without rooting. so they have to work out those issues anyhow
