Help Auto Reboot?
d4chris
Hey guys,
I have a weird problem with my S2: I don't know what happened tonight, but since then I am not able to shutdown my phone. Everytime I turn it off, it instantly out reboots. And I have absolutely no idea why this is happening. Additionally there is a MTP Application screen flashing up even though I do not have the phone connected via USB.
Anyone know this problem? If there is no help from you, I am probably going to reset it all...
Try a soft reset by holding the power button until it turns off. If this fails try removing the battery for a few minutes. If those don't work then you probably will have to do a factory reset.
