Help Auto rebooting when using Copilot
casarosa
As anyone experienced this problem at all I use copilot and have discovered that after approximately an hour of directions the phone will suddenly switch off and auto re-boot. Once up and running again I can carry on using Copilot as though nothing had happened do you think the phone gets overheated it was not positioned by any heat source
Kindest Regards
Sometimes a spontaneous reboot is the cpu or other system/hardware component responding to overload, given there is not a true bug in the app/widget being used and also that no sync loops, etc are occurring (Facebook and Gmail attempting to sync at the same time, etc).
You can investigate this by making configuration adjustments in syncing and background updating apps/widgets such as weather and the aforementioned apps.
In short: you just may want to tread a bit more lightly on your device's resources.
Yep. Phone is overheating. I could have mine sitting in front of the cold air vent at 19 degrees and it'd still do it.
There is no cure. You need to return it to HTC to have the mainboard replaced.
