Auto Reject?
DILands
Android Expert
Samsung has an Auto-Reject function that will put specific callers directly to VM without the phone ringing. Does the G4 have this? NVM - I found it - under settings!!
phone - call logs - call settings - call reject - call reject mode - then select which mode you want. I have Reject calls on list.
No such feature on verizon g4's from what I can see.
It should be in your regular phone app, then at the top you'll see "call logs", when you're in call logs tap on the 3 dots in upper right and you'll see "call settings" tap on that scroll down to "call reject". That's how AT&T is. Hoping Verizon would be the same.
How is what you guys trying to do different than just opening up someone's contact and checking "All calls to voicemail?" Are you talking about manually rejecting a call to voicemail?
This is for typical Spam calls, not calls in contacts. Call Reject. Then with the Visual voicemail you don't even have to listen to their messages (IF they leave one) just delete it.
