Help Auto Rotate and Upside-down Camera
kylasaur
After the lollipop update, my auto rotate is no longer working and all pictures taken are upside down. They are right side up before taking them, but as soon as I hit the button, it is upside down and I have to manually rotate them. I've tried doing the figure 8 thing and shaking it.. Also, auto rotate does not working in any other app, video, etc.
Do you have any added apps installed that are designed to control screen rotation at all? I have one, and found that its settings had gotten a little confused after the upgrade. Once I set them back to how I wanted them, all rotation behaviors returned to the way they behaved before the upgrade.
I'm not sure, but I'll definitely start going through my apps. Thanks :)
