Help Auto rotate stopped working
rich6661
Member
Auto rotate on my LG G3 stopped working. I downloaded the advanced tools app and discovered my x axis is stuck.
Any idea how to get the x axis to release so the thing will rotate?
Thanks
I read that thread and installed the app and did see that my x axis was frozen. I'm really Leary of dropping the phone purposely.
I'll try the app you use to control rotation.
I already contacted LG and they recommend a hard reset of which I don't want to do.
Thanks klotar
I used the rotation locker app which works well with the quick settings in the drop down notification bar.
