Help Auto Rotating stopped working
How are you guys? Well i had a rooted phone for a while with no problems. Then an update came out for metro and i updated. Two days later i turned off my phone and then when i turned it back on it was stuck on boot. So i hard reset my phone but now the auto rotation is not working. also once a day the screen turns black and i have to take out the battery to reset it. Any ideas?
Fully reset (factory reset) and clear all data and caches (system cache, Dalvik cache.)
Reflash the stock ROM.
Clear data. Clear cache.
See how it runs for a while after that.
Same exact thing happened to my phone. Turned out it was a defective phone so download an app that can detect if the sensors are working properly. I'm not sure what the name is but try and check the play store
