Help Auto Sync
age109
So i removed the power control widget that had toggle switches for gps, bluetooth, wifi, autosync, and brightness.
In doing that I also disabled autosync and gmail wasn't delivering emails until i manually synced it. I'm looking for the autosync setting without using the widget, but can't seem to find it. Does anyone know where it is located?
I thought it was under "Settings -> Data Manager -> Data Delivery -> Background Data" but I have a widget to disable background syncing and when I turn it off, that still stays checked. You could always just re-add the widget and turn it back on.
Hi, i found this theard after i had the same problem. however i shut mine off when i was just seeing what all the widgers were. did you ever find a way to make it work again w/o adding that widget back?
phone: atrix
skill: noob
