Help auto sync
dwsmith
I have auto sync turned on and set to update ever 15mins; however, I have to manual sync the phone for it to sync. Does anyone have any suggestions on how I can fix this issue?
Also, I have my calendar set up to sync from Outlook. I have the Sync settings to take the newest from Outlook and not the phone as well.
So the problem here is that I edited a series of events by removing just one occurrence. However, even when I sync the phone, it won't remove that one occurrence. If I try to remove it manually, it only removes the whole series not just the one event. Does anyone know what to do? Or am I overlooking something and I should be able to remove just one event?
