auto wifi
nebler
Hi guys, is it worth using an app that automatically turns the wifi on and off depending on my location, or wont it make much difference to my battery? i usually leave it on all the time, as i usually forget to turn it on again when i get home.
if a good thing to have , which app do you recommend?
cheers
ben
