Root [Avail] [UPDATED] TouchNav Recovery, sd-ext fixes, yaffs2 or tar versions [RECOVERY]
stayboogy
Android Expert
TouchNav Recovery
[updated version]
FEATURES
sd-ext (extended sdcard partition) are now hardcoded (should fix any previous issues)
sd-ext vfat versions
sd-ext ext3 versions
yaffs2 versions--make only a .yaffs2.img
tar versions--make only a .tar archive
(both yaffs2 and tar versions will restore either type)
backlight now brighter
same, power button toggle display after 3 full scrolls
same, awesome menu and features
same, awesome touch navigation
INSTALL FROM EITHER STOCK RECOVERY OR CUSTOM RECOVERY
ENJOY
(LINKS)
touchnav-roamer-vfat-yaffs2
touchnav-roamer-vfat-tar
touchnav-roamer-ext3-yaffs2
touchnav-roamer-ext3-tar
stayboogy,
I've moved your thread to the Merit all-things-root area for you--let me know if it really belongs in the Avail area instead.
Cheers and thanks!
stayboogy,
Cheers and thanks!
YES, it belongs there...
it's for both the avail and the merit, they are the same exact device, hence the reason i posted it there... the thread already exists in this section.
