I am starting a business and will need a smartphone to process credit cards The AT&T Avail seems to be the cheapest choice if it works with Square, but I don't know if it does.
If someone had an Avail and could check if they could download the Square app, that'd be great.
Here's the requirements to run Square:
Many Android devices are supported at this time. Supported Android devices have:
Google Android 2.1 or higher
Note: We do not currently support Honeycomb at this time. We also cannot support any modified versions of Android at this time.
A 3.5mm headset jack with microphone (audio jack adaptors are not supported)
A screen size specified as Normal or Large (Small screen sizes are not supported)
GPS enabled
Access to Google Play (previously known as the Android Market)
Code:
https://help.squareup.com/customer/portal/articles/156594
